Hysyde
I kind of jumped the gun and bought a older Kubota F3219 power broom to put on my F2100. Attachments for these machines are becoming rare an I figured I should be able to flip it if I don't find much use for it.
I remember running these as a teenager working for a landscaping company and using it for spring clean-ups and de-thatching. I can't recall if we used them for fall clean ups and leaves and such.
I was really hoping I might get some use out of it windrowing leaves, pine cones and corn debris from neighboring fields. Would adding a set up casters in place of the drop legs help with this?
I thinking it might work as a landscape rake of sorts where I've cleared bush but a lots of debris (twigs, bark, etc.) remains?
I use a handheld power broom for gravel in my ditches and on the grass, and this will definitely help with heavy years.
I know it needs asset up brushes which I'm figuring is going to set me back about $600 (should I go full poly or 50/50 ploy/metal?). It will have about $1100 into it at that point. It's a big enough piece of equipment and roof space is limited, so if I don't finda good use for it, it may have to go.
