curdy
Just bought a farm out in south central PA and I'm trying to figure out what tractor to get for it. I'll do my best to describe what I'll be doing and any advice you can provide is greatly appreciated on what I should be looking for!
I'm a used equipment type guy, I don't like paying more for brand new things unless it really really makes sense for me to do so. Especially since I'm just getting started out, and my needs may change some as I go along, buying used probably makes the most sense...not to mention that I need to really watch my expenses (who doesn't these days right?). So I also want to keep maintenance costs in mind (just because something is lower priced up front, doesn't mean it is long term.)
The property is 50 acres, rolling terrain. Our interests are in pastured livestock.
IMO, these are my needs as I see them now:
Priority
Mowing (around 2 houses, under 5 acres)
Loader work
Secondary needs
Brush cutting
Driveway grading
Loader
Given the frequent need for both mowing and loader work, I think a loader with a quick detach/attach is a must.
Trans
With obstacles around the houses and barn areas, I think a hydro trans is going to be the most ideal. I haven't operated a tractor with a shuttle shifter before, so let me know if that would be good for my needs and if it would be less to maintain.
Size
My loader needs should stay under 1000 lbs and I have a good neighbor with a big loader for the occasional need for anything over that. My thought would be that a shorter frame would be helpful for the mowing with tighter turns, and my lighter loader requirements doesn't require a larger frame. I also think having it a bit lighter (around 2k)
Power
Not sure of my HP needs. I'd rather not just 'get by' on power and find that I wish I had more. Occasionally its OK, but not often. I'm thinking 30 HP is a good #? I won't be brush hogging large fields, just along fence lines and some smaller areas, so I would think 5' should be good.
$10k is my top # for the tractor, FEL, and mower. There was a JD 955 with under 900 hrs, FEL, and 72" MMM for sale locally that I found about a week too late. It sold for $9700. That would have been pretty ideal I think. I was disappointing when I called and found it had sold.
Need some advice on what models would accomplish what I need and open to any other advice on things I should be considering. I'm not in a bind where I have to find something right away, but I think before spring would be ideal. If anyone knows of something for sale, let me know. I am fine with traveling to get a good deal.
Thanks so much in advance!
Priority
Loader work
Secondary needs
Brush cutting
Driveway grading
Loader
Trans
Size
Power
