Now on to draft control, shear pins, and plowing.
Draft control WILL NOT prevent you from shearing pins when you hit something substancial enough to trip the plow bottoms. It takes a split instant for the draft control to react to a sudden increase in resistance. You've already hit whatever it is that's shearing the pins. Draft control doesn't anticipate a buried obstruction and raise the plow over it. That's not its function. That's why trip beam plows are used. Draft control, in it's INTENDED form, as designed by Harry FErguson (of Massey FERGUSON fame), is intended to keep a plow (or any soil engaging implement) at a steady depth, all the while making gradual movements to keep the drawbar load (measured at the 3-point hitch draft arms) at a constant load. As the draft load varies because of changing soil conditions, or variance in shape of terrain, the draft control makes those gradual movements. When draft control senses an increase in resistance, it will raise the implement SLIGHTLY and GRADUALLY to reduce the resistance, then return to the pre-set draft depth as soon as that increased resistance is passed by. . As it raises the implement, the hitch pull down on the rear of the tractor, increasing available traction just as if the tractor weighed more. The purpose of Ferguson's design was to allow a relatively small tractor to do the work of a much larger unit. It simply made tractors more efficient at handling heavy draft loads.
Shear pins (or better yet, re-set-able saftey trip beams) are intended to protect the plow and tractor from that sudden jolt when the plow strikes that "immovable object", be it a rock, a root, or whatever hidden obstruction it is. If you're shearing pins, you CAN use a harder bolt, but be ready to get slammed into the steering wheel if you do hit something hard. (BTDT, grew up pulling old solid beam plows) If it's relatively "soft" roots that are tripping the beams, you MIGHT get away with harder bolts, but you'll still get a good jolt as the tractor pulls through them. Rocks? Well, harder shear bolts might just cause you to shatter a plow share, moldboard, or even bend the plow beam. Those shearbolts are there for the protection of you and your equipment.
