bottom plowing
   / bottom plowing #1
TMBRWLF
Stover, Mo.
MF1739E
New member here with a question on plowing. Tractor has 59 horsepower, looking at plowing options, can l run a 3 bottom or should l stay with a 2? I've heard a minimum of 15hp per bottom, not sure if thats a good guide or not. Unsure of soil type at this time. Any thoughts on this with minimal info? Thanks for the add to the site....
   / bottom plowing #2
Welcome to the forums! You will not have any problem with a three bottom plow with a 59 HP tractor. Ford 3000 would pull a three bottom without any problem at all and it was 47 hp I believe. Plus it was two wheel drive, is yours tractor a 4x4 or front wheel assist?
   / bottom plowing
Hello xrsrfn. The tractor im looking at is a MF1759 won't be ordering for awhile but am looking at attachment & options for this. It's a 4x4 cab model power shuttle.
   / bottom plowing #4
There are an unusual number of good looking three bottom Moldboard Plows for sale on eBay at the moment.
LINK: three bottom plow | eBay
   / bottom plowing #5
Our old Case 730 was rated at 67 hp if I recall, and it would pull 4-14's all day. There were also 16 and 18 inch bottoms then as well. So keep the size in mind when you buy also. Happy shopping and welcome to TBN.
   / bottom plowing
Thanks guys. Think l'll look for a 3x14 when the time comes. Now to the kitchen. I smell homemade bread.....
   / bottom plowing #7
Dad has a JD2440 which is around 60 hp with a FEL. With a 2-16 plow all the way in the ground the tractor will lose traction even with the wheels locked. Tires are not loaded nor does it have wheel weights.
The ground is clay after 6" of topsoil.
   / bottom plowing #8
Grandfather's Jubilee 1953 model pulled 3 bottom. Plows should be cheap as most got retired around here when scrap got high. 2 bottoms were spared for gardens. Three and fours became history.
   / bottom plowing #9
Rule of thumb is 1 HP per inch of plow...
That HP is drawbar...
Gross HP is typically 15% higher than PTO HP which is typically 10-12% higher than drawbar HP...
We pulled 3-16's with D17 Allis Chalmers here in the NC Piedmont clay...
Those tractors were rated for 4-16's but here that clay made a difference...
Those tractors were rated at 48 drawbar so 3-16's were optimal...
At 59 HP your drawbar HP is gonna be in the 46 to 48 range...
You should be able to handle 3-16's in clay...
   / bottom plowing
Learning as l go here. Thanks for the good info guys :)
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1992 Ford E-350 Ambulance (A51692)
1992 Ford E-350...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
