bota blower
   / bota blower #1
kokopelli2
central maryland
kubota/b2910
so how hard is it to install the sub-frame for the b series snowblower? we have the belly mower, so we cant have both on at the same time.
thanks guys
   / bota blower #2
If the subframe for the B2910's snow blower is anything like the frame for the B2400, then it is simple.
Do you have a FEL on your tractor? If so, then you may need to add two bolt holes in the FEL mounting plate. Newer FELs have the holes already.
   / bota blower #3
There are two rods and clips plus a drive shaft if you are using a front pto. The switch between blade and blower takes but two seconds.......one lever to throw and lock into place.
You are right, can't use the mmm with the front sub frame attached.
4 MISC TIRES (A53843)
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
GRACO KING XL70-180 TANK LINER APPLICATOR (A53843)
GRACO KING...
