Boomer 41 losing power
   / Boomer 41 losing power #1
dismith550
Northern KY
Mahindra 2638
Going up slight hill loses power, engine Does not bog down, spit, sputter, does not lose rpm, no evidence of strain, no load, only pulling itself - its like engine not connected to wheels, 700 hrs. Adjusted clutch, helped a little, got worse quickly, adjusted clutch to extreme, is clutch connected to hydraulics? All fluids ok, new filters 20 or so hrs ago, I am adjusting clutch by making adjustment arm Longer, tried opposite way, clutch wouldn’t engage at all.
   / Boomer 41 losing power #2
You are sure it isn't the fuel filter? It was on mine. Ran OK until I started uphill.
   / Boomer 41 losing power #3
If fuel and air filter are good, are the tires slipping on the rims? There was another thread on here over the last week with the same problem & it was tires not turning with the rims.
PIPE TRAILER (HOMEMADE NON TITLED) 28FT (A52472)
PIPE TRAILER...
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
