Boom Pole
   / Boom Pole #1
Rick Jay
Platinum Member
Greater Springfield area, Massachusetts
Kubota B2910, also Honda HT3813 with mower and front blade.
Hi All,
I was doing some web-surfing the other day and stumbled upon a 3 pt. attachment called a boom pole. Searching this group and the archives, I've found very little mention of these things. At around $100 + shipping, they look pretty inexpensive. The ones I saw were at Northen Tool & Equipment.
I have a B2910 with a loader, backhoe and posthole digger. My questions are:
Do any of you have one of these?
If so, what do you use it for?
Approximately how high can it raise a load?
Is there anything that it can do that the loader couldn't?
Thanks.
~Rick
   / Boom Pole #2
I don't have one but I'm thinking of getting one. I have a spike tooth drag harrow which I use to to loosen soil before seeding native grass and to cover the seed after seeding. With a boom pole, I could pick up the harrow with the 3 point, instead of just dragging it around.
   / Boom Pole #3
Rick, Tractor Supply Co. also sells the boom poles with 1000 pound rating (for $69.99 a couple of years ago). With compact tractors, I suppose you'd have to be careful not to pick up the front of the tractor. I don't have one and haven't had a need for it, but I can see how they could be handy in some instances.
Bird
   / Boom Pole #4
If you get one be sure to get one made of square tubing instead of round. They are a little more expensive but the square tubing is stronger.
   / Boom Pole #5
Can't think of much that it will be used for in your case. If you don't have a loader, it is a really neat attachment. Since you also have a backhoe, you have all bets covered pretty well. I have seen them rigged on loaders to get some real reach for very light loads.
Never though much about square vs round, but the difference should not be very significant especially since most pipe is heavy wall. Now if you will make either of those shapes from chrome moly material, then we will talk about some real strength of materials. Actually the square is stronger on the diagonal, but you can't depend on that orientation for most uses.
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
TEST BID LOT (A50775)
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
