Boom out to maintain center of gravity
   / Boom out to maintain center of gravity #1
Tollster
Veteran Member
Benton, Pennsylvania
Kubota, BX23
I was putting some stone walls in to terrace some slopes in my yard. While using my BX23 BH to cut the sod a couple of inches down I felt somewhat uncomfortable when I had to move the tractor ahead to cut the trench due to the slope. First off, I increased the air pressure on the downhill rear tires, kept my out riggers close to the ground if I had lift off ( Hoping this may avert a roleover) and extended the backhoe towards the uphill side for added weight. I was surprised at how this helped in keeping the platform a bit more stable.
I was then able to extend the outriggers form the driver position to level up again and continue the job.
Anyone else here ever try this? I know its not a recommend practice, but definately reduced the sphincter factor.
Job complete.
   / Boom out to maintain center of gravity #2
Using the backhoe as a counterweight works good for me, you just have to remember not to forget it....I find that in rough country the hoe often drags when in its folded position so I swing up the dipper stick, then back into a tree with it....
2006 Chevrolet Express 2500 Cargo Van (A51692)
2006 Chevrolet...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
2001 GULF STREAM CONQUEST (A51247)
2001 GULF STREAM...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
