books on building pole barns
   / books on building pole barns #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I'm looking for a good book on building pole barns. Something that will cover the basics and then move on to unusual cases, such as higher than normal ceilings. Any recommendations?
   / books on building pole barns #2
My local TSC carries a book on pole barns. If you don't have one try Amazon.com, I'm sure they would have something.
Bud
   / books on building pole barns #3
Hi Danny,
You can learn much from a salesman if you appear to be buying. Go through several brochures from several different firms and see what they have for details. They might even offer you a good price and/or financing so you could have them do all the work.
You can e-mail me privately if you want more input from a structural engineer.
Yooper Dave
   / books on building pole barns #4
Not sure if you have an '84 Lumber' in your area, but they will sell small blueprint packages ( 15-30 bucks ) for building small structures. Includes everything from the basic friction pile, clay floor pole barn, to the nicer concrete floor steel buildings.
If you are looking for the cheapest way, friction pile is the way to go, especially if you can get by the permitting, as in Ag use, and no power or water. That's what I did. Don't fool yourself either... they do look nice. My horses have no problem with it.. nor does my tractor.
Soundguy
   / books on building pole barns #5
When I built my Pole Barn I found the following books to be very worthwhile. Click the links to go to a description of the book on Amazon.com:
<A target="_blank" HREF=http://www.amazon.com/exec/obidos/ASIN/0913589160/qid=1028808907/sr=1-2/ref=sr_1_2/002-2518012-9762429>Practical Pole Building Construction</A>
<A target="_blank" HREF=http://www.amazon.com/exec/obidos/ASIN/0882661701/qid=1028808907/sr=1-3/ref=sr_1_3/002-2518012-9762429>Low Cost Pole Building Construction</A>
<A target="_blank" HREF=http://www.amazon.com/exec/obidos/ASIN/0882667734/ref=pd_cp_nsr_b_1/002-2518012-9762429>How to Build Small Barns and Outbuildings</A>
I also based my barn on a set of plans from 84 Lumber - modified to meet my needs.
I built my Pole Barn about three years ago. It is 40' X 32' and has three "bays" one of whch is closed in, and insulated for my shop.
The following link <A target="_blank" HREF=http://members.aol.com/wvbills/Construction.htm>My Pole Barn</A> shows the construction process and the "guts" of the structure.
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/6-101831-snow011902.jpg>This link </A> is a picture of the finished building taken during our one snow event last winter.
"What is a friction pile?" I was wondering that too.
   / books on building pole barns #8
Friction Pile
Piling supported by the friction with the soil surrounding it. Sufficient friction is developed between the sides of the piles and the soils to hold up the structure.
   / books on building pole barns #9
Excelent definition.. I probably wouldn't even have described it so well without pulling out my eng's reference manual.
For those wondering about the theory of it, think of it like this:
A piling sunk into the ground. While very little ( respectively ) force will pull the piling straight up. Force applied horizontally
to the piling creates friction on the forward and aft surfaces that are in contact with the ground, making it very difficult to then remove the piling upwardly. Therefore, wind force acting on a pole barn, actually titens the pilings 'grip' on the ground. kinda like a chineese finger puzzle.
Most pole barns that do not utilize a standard footer or monolithic slab, typically employ friction piles as supports. Cheap and easy.
Soundguy
"<font color=blue>Friction Pile
   / books on building pole barns #10
>Most pole barns that do not utilize a standard footer or monolithic slab, typically employ friction piles as >supports. Cheap and easy.
Ahhhhh, at least two of the books listed in the above post recommend using concrete collars at the bottom of the pole only (around the poles, filling the hole a foot deep with concrete, not necessarily under the pole, spikes driven into the pole for bonding aid). Reasoning as I gleaned it from the texts was to add bearing area, greatly add to withdrawl resistance, and yet, since both the ground-level area and very bottom of the pole are not concrete covered, there is still good chance that the pole will not rot. How does your definition of friction piles equate to the concrete collars idea? I followed the above advice, but I gather that a lot of professional builders simply drop in a concrete "cookie" and plunk in the pole. And a lot of self-builders concrete them in to ground level, thinking they need the strength. The latter makes me wonder how long their poles will last being trapped in concrete all its life. I've seen what that does to wood.
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
UNUSED AGT INDUSTRIAL SDA-140T LOADER (A51243)
UNUSED AGT...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
