Bolts To Studs On BX Front Axle
   / Bolts To Studs On BX Front Axle #21
Every time I have to remove and remount a tire/sheel on the front of my BX I curse them for using bolts instead of studs. So, I bought a 12" piece of 9/16" X18 threaded rod and lug nuts to replace them. I cut the rod into eight 1 1/2" long pieces and cleaned up the threads on the ends and made sure the nuts threaded on freely. This afternoon, I picked up the front of the tractor and pulled each wheel and installed the studs with a liberal amount of blue Loctite, let it set up, applied some antisieze to the threads and bolted the wheels back on. Now I can just line up the studs and holes, slip the wheel on and torque down the nuts with no profane language.
Yes, I see the bulge in the sidewall of the tire, it's coming back off on Monday and will be replaced.
That's a good fix. I had a similar problem on my BX255D with the bolts on the rear wheel constantly loosing up, don't know why. Anyway, the threads in the axle were striped, so I just drilled out the axle holes with 1/2" bit, and used grade 8 bolts and locknuts.
2019 CATERPILLAR 336 EXCAVATOR (A60429)
2019 CATERPILLAR...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
