Bolt Size of the Tie Rod for Kubota BX1800
   / Bolt Size of the Tie Rod for Kubota BX1800 #1
nosplace
What the thead size on the steering cylinder or the Tie Rod for the BX1800. I damage the threads and need to clean it up with a Tap/Die. Are they 14MM?
TIA,
Don
   / Bolt Size of the Tie Rod for Kubota BX1800 #2
I will bet they are English.
Buy the range of bolts, align them with light behind ('teeth' should 'nest'), return 'em.
Been my experience, if Metric, the C/F equivalent is a ratio (by country?) but distinct enough to eyeball over an inch or so of alignment.
   / Bolt Size of the Tie Rod for Kubota BX1800 #3
TIA,
Don
To confuse the issue more - there is a Japanese Industrial Thread. And I'll bet, that's the thread. I lost a Zerk fitting on my Kubota. Couldn't get metric or SAE to fit. Ordered one from the Kubota dealer which threaded in just fine.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
Wheels and Tires for Four-Wheeler (A51573)
Wheels and Tires...
