Bolt size/grade
   / Bolt size/grade #1
Mtsoxfan
Platinum Member
Newark Vermont
Kioti 3520SEH Holland TC29D
Ok, I made the mistake and bought bucket skis from VEVOR. Installed on bucket as soon as they arrived, 20 minutes of moving snow, the 3/8" bolts and corresponding nut were trash. Bolt bent, spot welds on nut severed. Not brain surgery skimming snow off driveway, so I'm chalking this up to inferior parts. Contacted VEVER, who sends a ton of repetitive responses, bottom line they will give me $20 or replacement. As they are new, bolt system is crap. For $20, I figure I can get a couple of stronger bolts and nuts. My buddy has a real welder, not the buzzbox I have and I'll be asking him to weld.
I'd like to go a size up for bolts/nuts. Any recommendations to size and grade? I'll be adding a second bolt to each ski, so there is less/no wiggling.
   / Bolt size/grade
7/16" grade 8 gets you a size bigger and has plenty of strength.
Thank you.
I think that having a second bolt set up will reduce movement. going to weld a piece of 1/2" rebar to top for leverage when tightening. A knurled knob only gets so tight. Now to find a local place that sells grade 8...
   / Bolt size/grade #4
Most likely due to improper use. The fixing bolt is not meant to take any stress. The bucket needs to be flat on the ground with the skis pushed all the way back. You can't back-drag with these on. You'll leave an inch or more of snow on a flat surface. They are wear items and probably good for one season at best.
   / Bolt size/grade
Yes, they were as tight to bucket edge as possible. It could have been driver error. They could have bent from poor quality, and pivoting when turning. Hence my plan to add a second bolt.
I actually leave an inch or snow when I was using a blower. packs nice and lessens the chance of digging up driveway.
   / Bolt size/grade #7
If the skids were mine, I would go right to a 1/2" bolt. Drill (tap drill), tap the skid, then use the bolt to hold the nut in place so you can weld it. The threads would then be through the weldment, and the nut.
   / Bolt size/grade
It the skids were mine, I would go right to a 1/2" bolt. Drill (tap drill), tap the skid, then use the bolt to hold the nut in place so you can weld it.
Thank you, great idea...
   / Bolt size/grade #9
...or you could clamp the nut to the piece and weld it, then tap drill/tap through the nut. That way the nut helps guide the tap straight. :geek:
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
2017 Nissan Altima Sedan (A48082)
2017 Nissan Altima...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
