Forks Bolt-on quick attach mounting brackets???
   / Bolt-on quick attach mounting brackets??? #1
scarhead26
AR
Mahindra
Bought a set of spikes to use as forks, thry are equipped with bolt-on pin mounting Brackets and I need the quick attach as my Mahindra 3616 has the quick remove lever system. Anyone know a place on line the sells these?
   / Bolt-on quick attach mounting brackets??? #2
Not sure I understand your question exactly, but if you want to bolt a universal skidsteer quick attach plate to your 'forks' instead of welding it..... just drill some holes in the QA plate and bolt it on. Never seen one specifically for bolting on, but no reason you can't bolt on one that is made to be welded. Just use the appropriate type, and amount of hardware.
Good idea man, I will do that!
2010 BIG TEX 16 T/A TRASH TRAILER (A55745)
2010 BIG TEX 16...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
2021 Toyota Rav4 AWD SUV (A55853)
2021 Toyota Rav4...
