BOLENS TX1500F EXCESSIVE NOISE AND BLACK SMOKE FROM EXHAUST
   / BOLENS TX1500F EXCESSIVE NOISE AND BLACK SMOKE FROM EXHAUST #1
imperatif
Montréal Canada
Bolens G174
Last year I rolled on the side with my Bolens/Iseki KE75 tractor. I put key and throttle arm in ''off'' position but engine continued to run and even ran at full blast for about 10 long minutes. I don't know what it was using as fuel since both ignition and throttle were shut off. When it stopped, I turned tractor back on its 4 wheels and let it cool off. A few hours later it started ok but it was noisy and black smoke was comming out of muffler. I changed oil and all filters. When cold it starts well but still smokes a lot and is so noisy that I have to wear ear protection. When hot (after 30+ minutes use), if I turn it off, it will not start unless I let it cool-off (battery ok but engine seems to offer resistance). Now, 1 year later, I still get very heavy smoke out of muffler and excessive noise; all other features of tractor work well (front loader and backhoe) so I want to try to fix imyself the 33 year old tractor. Ihave repair and service manuals, know a little bit about car mechanics but nothing about diesels. (Where do we take compression test?, Can it be valve adjustments? Bent push rods? Any ideas where to start?
L'an passé j'ai tombé sur le côté avec mon tracteur. J'avais fermé l'ignition et les gaz mais le moteur a continué à plein gaz pendant 10 minutes. Une fois éteint, je l'ai remis sur ses 4 roues et l'ai laissé se refroidir. Plusieurs heures plus tard, il a assez bien parti mais très bruyant et grosse fumée noire venant du silencieux. J'ai changé l'huile et tous les filtres. Aujourd'hui il démarre bien mais toujours beaucoup de fumée et bruit pas endurable sans protection. Quand je l'éteint après 30 minutes, il ne repart pas sans le laisser se refroidir.Ce tracteur a 33 ans mais il a un loader en avant et une pépinne en arrière; je veux le garder et essayer de le réparer moi-même. J'ai des notions de base en mécanique-auto pas pas en diesel. Des idées quelqu'un???? Par où prenons-nous le test compression sur un diésel? Les valves mal ajustées seraient elles possible? Push rod croches?
   / BOLENS TX1500F EXCESSIVE NOISE AND BLACK SMOKE FROM EXHAUST #2
The fuel it was running on was its own oil. Now the engine over rev'ed
and was not picking up oil to the oil pump from being on its side
so the main bearings ran dry of oil. The oil also could have been
filling the cylinders and bent a rod or two. Rod bearings could
also be shot. And so on.
Wow ... thank you for the info.* Should I sell for parts? or if I open it up will I be able to get 30 year old parts? Do I need specialised tools to open and close?
Why am I getting black smoke now?
thank you for your patience
   / BOLENS TX1500F EXCESSIVE NOISE AND BLACK SMOKE FROM EXHAUST #4
You will need to remove the head to check the cylinder walls
to see if they are damaged. You will need a torque wrench to
tighten head bolts or any other bolts needing correct torque.
New head gasket down here is around $130 US.
You would also want to drop oil pan to at least check
rod bearings. Further disassembly should be done
to check crank shaft for damage also. You would
have to split tractor in half if you need to remove
crank shaft. The cheapest thing to check is
to drop oil pan and remove rod cap to inspect
rod bearings and crank journals where rods
bolt to.
   / BOLENS TX1500F EXCESSIVE NOISE AND BLACK SMOKE FROM EXHAUST #5
If the rest of the tractor is in good shape you may
want to look for a replacement engine.
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
2016 Dodge Charger SRT Hellcat Sedan (A50324)
2016 Dodge Charger...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
