Bolens Iseki FEL build
   / Bolens Iseki FEL build #1
badboyrcg70
Bolens/Iseki 1502 HST
Thought I would post up my FEL build.
I tried for 2 years to find an original 1517 loader for this tractor but found none.
So I bought an older FEL an am modifying it for mine.
Fabrication is almost done need to modify hydraulic lines and replace dry rotted lines off the old model.
I also found an agg tire combo to replace the turf tires.
   / Bolens Iseki FEL build #2
Wow I had to study the pictures for a while to see all modifications you made. It looks like it fits well. It looks like it is bolted solid or did you manage to hide a quick attach in there somewhere?
Make sure you have a lot of ballast when you fill up that bucket!
Installed hydraulic block and hoses with quick disconnects up to the control valve.
Had to replace 1 of the hoses on the control valve due to dry rotting.
Cross brace finished which is also where hard lines will sit
Next need to modify hard lines.
Looks better with the grill installed
Nope no quick disconnect there. Will have to remove 12 bolts to take it off.
I had to cut 16" off the lift arms when I modified it. Bucket has been shortened 6" per side
and now measures 51" across. Uprights were shortened and plates made to attach to tractor mount which I fabricated using templates I made from someone who had an original 1517 loader.
Rear tires are filled with washer fluid and I have wheel weights and some suitcase weights to add ballast if needed
but I really don't want to over load it so Ill stick to 6-700 lb max load.
   / Bolens Iseki FEL build #5
Nice job! I did a similar project on my Mitsubishi. I found a Freeman FEL frame at the local scrap yard. I built the bucket, uprights and subframe from drop cuts I found there and bought a Ford joystick control valve and cylinders on Ebay. I had to cut the lift arms down and narrow it since it had obviously come from a much larger tractor. To take it off, I have a small "gantry" (actually an old porch swing frame) that I drive under and support the loader arms with ratchet straps, pull the lift arm pins and 4 quick disconnects at the valve and back away. It is quick and easy. The subframe, uprights and valve stay on the tractor but it has never created any kind of issue. Has worked great for about 10 years now.
Hard lines cut down and secured with weld nuts.
Now got to get the rest of the hoses.
   / Bolens Iseki FEL build #7
Nice work, I like successful DIY work around projects.
If no mistaken the engine is probably a Mitsubishi 3 cylinder like I have in my MT180D.
Actually the tractor could be a rebadgered Mitsu.as I know they did some for Bolens as well as some Fords.
   / Bolens Iseki FEL build #8
Nice job! Make sure you look into adding a tooth-bar on that thing, I built one based on the piranha tooth bar design and its doing great. Do you plan to add ROPS in a near future? Tractor + loader = a lot more way for things to go bad in a hurry....
TY
I will look into getting one. Need to build a scraper blade for the rear next.
As far as the ROPS go I am 47 on the waiting list for ROPS rebate grant funding.
I have tried to find an original but for what they want I might as well buy the Hercules fold down version.
Hopefully in the next year Ill get the call. I went from 75 to 47 in 6 months.
   / Bolens Iseki FEL build #10
Are you using compression fittings on the steel lines? How do they hold up over time?
2015 Chevrolet Equinox AWD SUV (A42744)
2015 Chevrolet...
2016 Mack LEU613 T/A Scorpion Side Loader Garbage Truck (A44571)
2016 Mack LEU613...
1998 CPS TRAILER COMPANY BELLY DUMP TRAILER (A45046)
1998 CPS TRAILER...
2014 FREIGHTLINER CASCADIA (A45046)
2014 FREIGHTLINER...
2016 Ford Fusion S Sedan (A44572)
2016 Ford Fusion S...
2014 WESTERN STAR 4900 SF (A45333)
2014 WESTERN STAR...
