Bolens H1502 Three Point Problem
   / Bolens H1502 Three Point Problem #1
dstankus
Hydro 1600 Eliminator
I have a Bolens H1502 that has a problem with the three point lift. It lifts, but stops as soon as it sees a load. I can grab it and lift it up and it will stay where I leave it but it wont raise under even a modest load. The three point doesnt seem to leak down once raised up. I cleaned out the suction filter near the front of the container and there were a bunch of metal shavings in there. The filter seemed to keep them back but they obviously they came from somewhere.
After cleaning out the suction filter - it seemed to lift a little stronger. Is there another filter that should be cleaned out? Is the pump shot? Any advice would be greatly appreciated.
   / Bolens H1502 Three Point Problem #2
Did you ever get this figured out? Im experiencing the excact same thing.
I did - it was a blown o-ring. I had to take the whole thing apart, fish out all the little bits of o-ring and then put it back together. Works like a charm now.
   / Bolens H1502 Three Point Problem #5
I just ran across a similar issue where the 3-pt would raise fine, but would not come down (more than the small amount of normal leakage past the piston which takes weeks with no linkage on it) on a tractor that has been sitting for a while. After taking a few things apart and not being able to see anything wrong, I took off the link bar from the 3-pt arm to the control lever and ran it up as far as it would go. Apparently when it "dead-headed" there was enough residual stress that when I released the control lever it would go down just a little, like maybe a 1/16" at the far end of the arms. A couple times doing this it finally freed itself up and works as it should now. Got lucky I guess...
   / Bolens H1502 Three Point Problem #6
I'm not feeling lucky on this one. Thought I found a bad oring on the big banjo bolt for the hydraulic return line, replaced it and still hardly any power to the 3 point hitch and the drive wheel are slow and noisy and after a little bit just pretty much stop working. I pulled the pump off the front left hand side of the engine and am going to try to have it looked at or just get a replacement. I hate thinking about buying a new one, putting it on and havering it do the same same, this thing is kicking my *****!
2020 KENWORTH T680 SLEEPER TRUCK (A52141)
2020 KENWORTH T680...
Polaris Side by Side (A50324)
Polaris Side by...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
