Buying Advice bobcat tractor front loader control
   / bobcat tractor front loader control #1
kstone71
john deer 330
hello
My understanding from reading a few post is the 1000 and 2000 series tractor front end loader controls are not multifunction but are diverter controlled { either or}
few questions
1, is this a common limitation on small tractors compact subcompact on other brands ?
2 , does bobcat use a control by wire on theses two { diverter valve body ? } and can this be upgraded after the fact for full multifunction of lift and curl at same time ?
3, is it purely mechanical in control body and need to be upgraded to a different valve body ?
4, how much off a problem is it , do you get used to it does it cause a problem for other attachment { grapples , pallet forks ,sweepers, snow blowers , etc}
5, is the valve body for the 4000 and 5000 series different can it be used?
thank you
   / bobcat tractor front loader control #2
I can't help with too many of your questions, but I have a 2000 series. If you full throttle the control in any direction you get one function at a time, up, curl, down, etc. If your moving slower you can lift up on the loader arm and curl down the bucket at the same time, but it has to be slowly. Same with my grapple/ third function. I can curl down and open the grapple lid at the same time as long as I'm not moving to fast with the curl function.
2013 Volkswagen Passat Sedan (A48082)
2013 Volkswagen...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
434669 (A48836)
434669 (A48836)
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
