Bobcat t250
   / Bobcat t250 #1
pierce27360
Springfield, Louisiana
Massy Fergusson, 135
Good morning. My son in law has a bobcat t250.
It starts and runs great, will run all day. The problem is when you turn it off, it will not start back, at least for several hours or the next day.
He has replaced several parts to no avail.
Would appreciate any troubleshooting advice that can be shared, thank you, Calvin
   / Bobcat t250 #2
Try the Bobcat Construction Equipment forum here. If you're lucky Dennis (SSdoxie) will have suggestions for you. Good luck!
   / Bobcat t250 #3
If it is diesel it is probably the shut off solenoid.
I had a 225 CAT engine that had that problem. I could not afford the solenoid at the time so I would shut it off and then turn key right back on and leave it on because I was going to start it soon.
I could also crack a fuel line and relieve pressure and it would start.
10" I BEAMS & 10" CHANNEL IRON UP TO 40' LONG (A51247)
10" I BEAMS & 10"...
2R PLANTER W/ COLE PLANTERS (A51247)
2R PLANTER W/ COLE...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2022 LMC H40024 LOT NUMBER 105 (A53084)
2022 LMC H40024...
