Bobcat S175 won't start
   / Bobcat S175 won't start #1
fencer
I have a S175 Bobcat-the engine won't turn over. I have checked the starter and battery...both okay. Earlier today, the guages all lit up--slowly, but now...nothing....not even a click. Of course, can't find my manual! Any help appreciated. Thanks.
   / Bobcat S175 won't start #2
check your grounds
how do you know your batt and starter are OK?
i'm a bobcat mechanic
   / Bobcat S175 won't start #3
check your grounds
And you own a Kubota???
Seriously, back to the OP post:
Those dim lights on the gauges indicate a battery going bad. The easiest, least intrusive thing to do is jump start from another vehicle (you might have to let the battery charge for a short period of time while those jumper cables are attached so make sure the charging vehicle is at a fast idle). Even if the starter spins faster, it may not be fast enough to start the Bobcat's engine but it'll indicate you're due for a new battery (and eliminate the ignition switch and wiring as a possible cause). But, before buying that battery, make sure your cables and connections (battery and starter) are in good condition.
If the starter still doesn't engage, it's time to troubleshoot the ignition switch and wiring.
   / Bobcat S175 won't start #4
How are the battery cables? I first repaired, then replaced my neighbors Bobcat 773 cables. He thought it was the battery.
REMLINGER 2300 LOT IDENTIFIER 255 (A53084)
REMLINGER 2300 LOT...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
(1) VISSANI REFRIGERATOR (1) FRIGIDAIRE REFRIGERAT (A51248)
(1) VISSANI...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2014 CATERPILLAR...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2020 John Deere 9470RX Tractor (A53342)
2020 John Deere...
