Bobcat oil leak
   / Bobcat oil leak #1
rich3930
atwater,ohio
john deere 510 backhoe
I'm having a terrible time locating the oil leak on my bobcat 773, I have replaced three lines so far with no success ,is there a dye that can be added to the oil to pin point the lead. It is difficult to work on and i can"t run the machine with the cab up. I would appreciate any offers of help.:eek:
   / Bobcat oil leak #2
John Deere sells a hydraulic dye. I do not recall the P/N. but parts department should know.
   / Bobcat oil leak #3
The common way to find leaks is to start with everything clean. Most leaks don’t flow uphill so it’s typically possible to locate them.
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A51247)
1996 UTILITY 101"...
Mitsubishi Mini 2WD Truck  (A52384)
Mitsubishi Mini...
2005 GMC 8500 (A50123)
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 CFG Industrial SSECAG-Y (A50123)
2025 CFG...
