Bobcat CT450 (Kioti DK 45/50) Wiring diagram needed.
   / Bobcat CT450 (Kioti DK 45/50) Wiring diagram needed. #1
PaulP
I have a Bobcat CT 450 (cabbed model) and the horn was working intermittently but has now stopped. I believe the Bobcat is simply a re-badged Kioti DK 45 or DK 50).
Switch was tested and good. 12V power lead to horn is good. Horn itself tested good.
Black wire with white stripe doesn't show connectivity from switch to horn but we can't find any break or chewed sections from mice.
There are a hell of a lot more wires running to the horn than one would normally expect to include several that are terminated in the cable shield just prior to the horn itself. We did find one inline fuse (tested good) in that bundle on a wire that wasn't being used so that leads us to believe there could be another somewhere along the line.
Looking for a wiring diagram that may lend some support.
Trying to avoid simply by-passing the harness and running a new ground to the horn if possible.
Thanks, Paul P.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
2015 MACK GU713 (A50854)
2015 MACK GU713...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
Adams 8 Ton Weigh Hopper (A51039)
Adams 8 Ton Weigh...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
