Bobcat CT445 starting problem
   / Bobcat CT445 starting problem #1
Tystix
Bobcat CT445SST
Have a tractor that is driving me crazy. If you pull the fuel shut off solenoid it start fine. If you have the solenoid out and the wires hooked to it and key the ignition I can manually make the plunger retract. When the solenoid is installed this does not happen and therefor it will not start. Anyone have any ideas?
   / Bobcat CT445 starting problem #2
If its a 3 wire solenoid.. theres 2 circuits.. 1 is PULL & the other is HOLD{RUN}.. it takes ALOT MORE amps to PULL the plunger IN for starting..
& just a few amps to HOLD it..
THATS WHY you have to push the plunger in when its in your hand.. THE PULL RELAY is probably bad..
OR its just a bad solenoid.. they go bad ALL THE TIME.. & its a weak point in the system..
Good luck..
   / Bobcat CT445 starting problem #3
Just do a search on "how to test your relay".. good luck.
I replaced the relay and the solenoid last year and it worked for a while now back to the same issue. I do not believe it is the relay because I can switch harness with another like relay and it does the same thing. The service manual shows how to test the solenoid and wants 18.6 ohms between 2 connectors on the harness. I'm confused at how that actually tests the solenoid?
My hold wire (blk/yel) looses 12v which is approx. 2 sec. as soon as the relay clicks. I know the pull wire (blu/red) is supposed to but not the hold. This just started and has me frustrated.
   / Bobcat CT445 starting problem #6
One more thing.. the solenoid HAS TO go to the end of its travel inorder to "stick" in the run position..
They are adjustable.. I've seen TO MANY that were out of adjustment & burned-up the hold coil..
The easiest way to tell is.. remove the linkage & get it to HOLD in your hand.. now compare the angle at which it hooks back up..
& it IS possible for the hold coil to burn up IN the solenoid.. & the run be OK..
Its normal for the "hold" circuit to drop off after a few seconds.. it keeps the system from overheating the coil in the solenoid..
IF it snaps shut & then drops off.. I'd say the "run" relay is bad.. it has to switch from hold to run in a matter of seconds.. just my guess..
I'd check the "travel" first & foremost..
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
2019 KENWORTH T880 (A50854)
2019 KENWORTH T880...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
