Bobcat Code 08-21 Hi Temp.
   / Bobcat Code 08-21 Hi Temp. #1
Joe Joe
Lee Vining, Ca
Bobcat 773, 2001
I have a code 08-21 Hi temp.on a Bobcat 773 and the gauge shows Hi Temp. it comes up from the time you start it up but coolant is running from 160 to 190 and oil Filter temp. is about he same when it is under load running a Brush Hog. All looks normal any thoughts?
   / Bobcat Code 08-21 Hi Temp. #2
Welcome to TBN :)
I moved your thread to the Bobcat Construction Equipment forum.
Thanks for moving it to where it should have been. I think that I have found the trouble I cleaned the battery posts and the main ground connections. and all seems to be normal.
   / Bobcat Code 08-21 Hi Temp. #4
glad you found it. A bad ground will wreak havoc on the computer. You might already try this trick but if you are mowing, put a piece of cut to fit AC filter between top of radiator and protective cover. It will help catch debris and keep you running longer before radiator plugs and you get the same error code. Metal window screen works well too. Mowing with brush mower out front will eventually lead to clogged radiators on a Bobcat.
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
METAL FILING CABINET (A53843)
METAL FILING...
UNUSED WOLVERINE TL-12-72W - 72" HYD TILLER (A51248)
UNUSED WOLVERINE...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
