Bobcat backhoe hydraulic question
   / Bobcat backhoe hydraulic question #1
Griffco
St. Charles MO
Bobcat T190, Mustang 940, Kubota L4330,
I just bought a used backhoe for my Bobcat T190. The main boom lift hydraulic drops a foot before catching when ever you push the lever to lower the boom. Does anyone know if i need to bleed the cylinder or if the valve on the control lever is the problem or ?? All the other movements on the backhoe seem to work fine. I did replace a couple of hydraulic lines on the backhoe that where leaking.
   / Bobcat backhoe hydraulic question #2
Cycle the boom about 5 to 10 times.
You could also switch hoses just to check .
   / Bobcat backhoe hydraulic question #3
After you get the air out and it still does it check the load check valve in the main valve. Might have a bad spring or dirt in it.
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
