Bobcat 943 hydro issue
   / Bobcat 943 hydro issue #1
topfli8979
Springfield,Missouri
Ford 1215
Picked up a bobcat 943 that sat for a few years not running. Rebuilt injection pump and she purrs now... But I have been fighting a issue with the right side drive hydraulics. After the oil heats up I pretty much lose all forward movement on right side , but do have stronger reverse. Pulled drive motor , and capped off hydro lines to test pressure . Reverse is 3800-4200 psi, forward is 1800-2000 psi max. I have swapped the two top relief valves, but no change. Still have to get bottom 2 out of pump, it's a tight fit. Other than relief valves, what could cause more pressure in one direction?
   / Bobcat 943 hydro issue #2
I think you are on the right track looking at relief valve if loss of pressure is only on 1 side in 1 direction.
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
FRONTIER WR3210 LOT NUMBER 120 (A53084)
FRONTIER WR3210...
YANMAR YT359 TRACTOR (A51247)
YANMAR YT359...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
