Bobcat 943 Hydraulics operates in only one direction
   / Bobcat 943 Hydraulics operates in only one direction #1
Robertsroost
Inyokern, Ca
Bobcat 943
Bobcat 943 Hydraulics operates in only one direction, I accidentally ran the system low on fluid and now the arm will now only go up and the bucket will only tilt down in one direction.
I have cycled the system by raising and then shutting the engine down and cycling the pedal until the bucket comes back down under its own weight. I also have bled the system by cracking lines at the the cylinders. Need your help.
Thanx!:)
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
Brown 6' Disc Harrow (A50123)
Brown 6' Disc...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
