Price Check BOBCAT 863 STEER LOADER
   / BOBCAT 863 STEER LOADER #1
STEX
Boerne Tx
863 bobcat
I blew the engine in my Bobcat 863 , 1998 model, deutz engine. If buying a rebuilt engine about what would be the cost to put the new engine in (labor) and using any parts off the old engine that is necessary? Also about how long should it take to do this mechanic work? Thanks!
   / BOBCAT 863 STEER LOADER #2
I had the same happen to my 843 with the perkins engine. A factory reman engine was $6-7k and
they want a rebuildable core or it's another charge plus freight charges.
I had a local shop rebuild my engine. $2k for rebuild kit. $1.5k for machine work and labor. Probably
another $1k expenses in some new parts what I call "might as well". I did the remove and install labor.
These engines are fairly simple to unbolt and remove. I feel that I can remove one of these engines
in about an hour. I spent several hours cleaning before and after removal.
Thanks, Frank. I do not use my Bobcat for commercial work, just use it around my place so I am of course trying to get it done as cheap as I can. Thanks for the information.
   / BOBCAT 863 STEER LOADER #4
I forgot to mention these prices are from 5-6 years ago. There are not many
options when you need to rebuild these diesel engines. My original engine had
over 9500 hours, had lots of oil leaks and getting very hard to start. You can
get as much in an engine as what the whole machine is worth. I found out
that the $ for perkins parts is high and hard to find. I couldn't find a way to
do it cheap and do it right.
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
