Bobcat 863 Fuel Issues & Engine Run Away
   / Bobcat 863 Fuel Issues & Engine Run Away #1
9inchaxle
Bobcat 863
Just bought this skid steer recently. This is my first chance at trying to get it started. When I purchased it I knew it had starting issues. I found poor flow from the tank when using the bulb. I also found very dark contaminated fuel. I replaced the fuel filter and primed the fuel lines to the filter until their was no air. My fuel supply is a gallon plastic bottle for now. I loosen a high pressure pump nut to see if the system would build high pressure and cranked the engine. It fired a couple of times with dark smoke, so I tighten the fitting and cranked some more. It started and ran at high RPM, Black smoke and would not shutdown, throttle position at idle key off & removed. I tried the manual shutdown lever, no effect. I pulled the fuel line out of my bottle, the engine shutdown in about 5 seconds. I have removed the fuel shutdown solenoid and checked it's movement it extends and retracts the arm. While the solenoid was removed, I moved the manual shutdown lever and can see a vertical stud move back and forth but I can not see or understand how they move anything in the bore. The electrical solenoid linkage does not interfere with the manual linkage. Does any one have a Idea the theory of operation for this? What suppose to move to shut down the fuel?
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2021 DELICUCIO BELLY DUMP TRAILER (A52472)
2021 DELICUCIO...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
