Bobcat 773G turbo
   / Bobcat 773G turbo #1
60lp
Bronze Member
Friendsville Tennessee
1020 john Deere,300B Deere backhoe,773G turbo Bobcat,LT30 Woodmizer sawmill with 2-cylinder air cooled diesel Engine
I知 inquiring about the the traction control panel my machine has around 1500 hour this panel gone bad the machine will not go forward or backwards or let the hand controls loader up or Down but rest of the panel is fine so what asking is they anyone offers a aftermarket control panel with toggle type switches or or anybody that is a computer guru that’s ´ brave enough go into this panel and do away with the finger touch buttons or the panel I致e tested everything and read all books on it and this control panel is what is pointing to thanks again all help will be gladly appreciated
   / Bobcat 773G turbo #2
Are you sure the panel is bad ? Do you have the controller beside the seat with lights ? post the sn# :confused3:
   / Bobcat 773G turbo
519018766
   / Bobcat 773G turbo #4
Start engine. Lap bar down. Press operate button. Press and HOLD LIGHT BUTTON. Code will be displayed. Post the code. :thumbsup:
   / Bobcat 773G turbo
machine shows no codes
   / Bobcat 773G turbo #6
That's strange. Have you tried lap bar UP and yellow OVERIDE button to see if unit will move ?
   / Bobcat 773G turbo #7
No codes present means problem is on input side of control function. Controller has no way to determine what or when operator pushes a button of moves a lever.
Look just below the hour meter window for the small LED lights (seat bar, valve, & brake). With key on: seat bar light should come on when seat bar is lowered, valve light should come ON when Press to Operate button is pushed, Brake light should come on after engine started and RPM over 650.
If seat bar lights and no other lights after pushing PTO button, check the plug connection at back of the left panel. Unplug it, clean, and firmly reinsert until snaps in place. You can easily access back of the panel by removing the headlight rubber seal and light.
   / Bobcat 773G turbo
I have checked everything inside and out still nothing I’ve been told the computer has gone bad
   / Bobcat 773G turbo #9
Have you had Bobcat of Knoxville field service tech come look at it. This panel is no longer current production but they used to carry a known good test panel to hook up to determine if problem is in left panel, communication wire to controller, or main controller
   / Bobcat 773G turbo #10
From what I understand you machine has joystick/hand controls. Not hand and foot pedals. If this in correct, you issue most likely lies within the joystick control system. That system of joysticks was troublesome and you will need a dealer to diagnose the issue with computer and then pray you can find parts if needed.
Manac Walking Floor Trailer (A50322)
Manac Walking...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
Electric Concrete Mixer (A51573)
Electric Concrete...
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2023 Canam Defender Lonestar (A51572)
2023 Canam...
