Price Check bobcat 773 turbo bob tach
   / bobcat 773 turbo bob tach #1
diawaguy
bobcat 773 turbo
why is my bob tach so hard to use even after i greased it and used sledge to unfreeze steel pin and removed bucket? i am using
   / bobcat 773 turbo bob tach #2
hard to say without seeing it. many reasons. cold temps change grease, sand in the grease around the pin, years of not greasing them, bent metal or dented pin from hard use...........
   / bobcat 773 turbo bob tach #3
Take the bolt out that handle pivots on then pull the pin, spring, handle assembly out of the Bobtach. Clean the pin and inspect for bend. Apply a light coat of grease. Clean the pin bore of the Bobtach and make sure the grease zerk is not plugged. Put it back together, pin should slide easy. Then grease the pins everytime you grease rest of the loader pivots whether you indend to take bucket off or not. 2-3 pumps of grease each time to keep the pin loose.
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Walking Floor Trailer (A50322)
Walking Floor...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2013 Ford F-150 (A50397)
2013 Ford F-150...
