Bobcat 773 Code 05-14 and 04-14 then turns off! Please help!
   / Bobcat 773 Code 05-14 and 04-14 then turns off! Please help! #1
dashin3
bobcat 773
Hello I have a bobcat that has about 1600 hours. Once I pull the lever down and turn on the lights. The bobcats turns off shortly. I have tried different things and cant figure it out. The codes that come up are 05-14 and 04-14 and then turns off. In the manual it says oil pressure low and shup off. However I have a pressure reading valve on the oil and it says the pressure is normal. The other thing is the lights on the board do not stay on, could this be something I can fix. I have tried so many things I am now turning to the internet hopefully someone can shed some help! If you have heard or had this experience please help.
   / Bobcat 773 Code 05-14 and 04-14 then turns off! Please help! #2
Call a dealer and give them the codes. What year is the machine? How long before it suts down? has it been in opeation or did you just buy it. Does the Hyd function? I too have a 773 as well.
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
