Bobcat 763 - moves by itself
   / Bobcat 763 - moves by itself #1
Zurpro
Calgary AB
montana
lately the unit starting to move by itself - levers are in center postions - cannot stop unit- have to keep moving levers back and forth to stay in position !!
   / Bobcat 763 - moves by itself #2
There is an adjustment for that down back at the pump. Cam rollers on the pump arms push against blocks fastened to the return spring plate. Cam rollers get worn then need adjusting. Procedure is in the Operation Manual, if you don's have on I suggest you get one. It is a little to detailed to post on here.
Thanks for the info :)
Non running toro mower (A48082)
Non running toro...
2019 Allmand Trailer Mounted Light Plant (A50860)
2019 Allmand...
2015 Mitsubishi FEC72S 16ft Box Truck (A48081)
2015 Mitsubishi...
John Deere 950A Zero Turn Mower (A50860)
John Deere 950A...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
UNUSED 20PCS 1.2 in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 1.2...
