Bobcat 763 error code
   / Bobcat 763 error code #1
Irene110
Okeana, OH
763 bobcat skid steer
Our bobcat worked fine and we rented a bobcat auger attachment. We connected it and drove it to where we were going to work and then went in for dinner. We came out and it wouldn't start. The panel lights started flashing when you turned the key. The error code is 0314 low voltage. We just installed a new battery 2 weeks ago. Even tried to jump it with no luck.
Any advice on what to do? Wasting money since we rented the auger!
Thanks!
Irene
   / Bobcat 763 error code #2
Key should be shut off and pulled from machine something drained the battery. Two weeks without much use could be you were running on battery only. Check your charging system and see if you are getting any voltage from the alternator. Why did you install a new battery two weeks ago? May have missed when you did and alt. was the problem. Take battery back and have the seller check it could be another bad battery.Clean everything including the ground strap. Take multimeter and check for battery drain with everything shut off. Test light would also show a draw. Electrical is a pain to track but it is usually something simple.
   / Bobcat 763 error code #3
:welcome: to TractorByNet! :thumbsup:
Remove the negative cable at the frame or engine, use a wire brush on the connector and the metal that it connects to.
Check the battery with a digital meter, 12.6 is fully charged. Maybe your new battery was not getting charged due to a bad ground or the alternator not working.
The battery was replaced because it was several years old and we had the very cold winter. We have been running it since the new battery replacement. It started right up today to remove the bucket and attach the auger through the hydraulic hose attachment. We left for 30 mins and came back out to the problem.
Quick Attach Pallet Forks (A47384)
Quick Attach...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
Year: 2020 Make: Cadillac Model: Escalade Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 73,021 (A50324)
Year: 2020 Make...
John Deere 4020 Tractor (A50514)
John Deere 4020...
CATERPILLAR 325FL CR EXCAVATOR (A51242)
CATERPILLAR 325FL...
