Bobcat 632 hydraulic hoses hooked up wrong need help
   / Bobcat 632 hydraulic hoses hooked up wrong need help #1
mnroofer
Rogers MN
Bobcat 632
Hi having problems remembering how to hook up hydraulic hoses on my Bobcat 632.
So here's what happen I blew a couple of hoses and unfortunately I did not mark them or take pictures and cannot remember which order they need to be connected.
If I hit the Lt foot pedal the arms will go up but not down.
The rt pedal will curled down but not up.
Any help would be great thanks.
http://i1014.photobucket.com/albums/af270/metroroofing/IMAG0861.jpg
http://i1014.photobucket.com/albums/af270/metroroofing/IMAG0860.jpg
http://http://i1014.photobucket.com/albums/af270/metroroofing/IMAG0859.jpg
   / Bobcat 632 hydraulic hoses hooked up wrong need help #2
The poblem you descibe is what happens whne the auxiliary control for the front auxiliary hydraulics is activeated but no way for oil to flow. Check you auxiliary contol lever and make sure the valve spool is nuetral, center position.
Thanks for the help the auxiliary hydraulics were stuck works great!
40ft Sea Container (A52384)
40ft Sea Container...
Adams 5T HC Spreader (A53472)
Adams 5T HC...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
