Bobcat 610
   / Bobcat 610 #1
Popeye1
MT
None yet
I recently bought 6 acres. I am planning to set up a little wood lot as I own a small bandsaw mill. I am planning to build on this place and will need something to do snow removal.
I have been looking at buying a tractor or skidsteer to help move logs, plow snow, and do some odd stuff.
I have found a bobcat 610 that a guy will sell for $1500, he said it runs good but needs a new clutch.
What do you all think? Is it a good deal or should I hold out for something else?
I am comfortable doing the mechanic work on it, as long as I can find a manual.
   / Bobcat 610 #2
I have a late 60's melroe 600 which is identical (with very minor differences like loader arm pin hardness). you can buy the copied manual on ebay for about $80 as I did and there are plenty of guys with them who post repair videos on youtube for tricky stuff like engine swapouts. The wisconsin motor is air cooled and around 24-27 hp so is up to pretty good loader work. Don't expect to move over the ground very smoothly at there is no suspension. I'd use a tractor with chains to haul logs if you don't need the tight turning of a skid steer because you will pay in terms of ease of running over uneven terrain.
Wright Sentar (A50120)
16FT flat bed trailer (A53424)
16FT flat bed...
2020 FREIGHTLINER M2 106 26' BOX TRUCK (A54607)
2020 FREIGHTLINER...
RING 3 STARTS HERE @ 9:30 AM (A54757)
RING 3 STARTS HERE...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
1998 ford f450 (A53422)
1998 ford f450...
