Bobcat 610
   / Bobcat 610 #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
How hard is it to adjust the steering clutches on a Bobcat 610? I can push my levers ahead or back far enough where they will stick (like cruise control). I also have the big material bucket for it and would like to find the normal smaller bucket for it.
Thanks,
Ash
   / Bobcat 610 #2
Ash:
I've been looking at a lot of sites telling you how to work on these 610's
and it seems fairly easy to tighten up the clutches. Take of the big nuts on
the side panel on each side and remove the cotterpins holding the clutch
shafts. Tighted the nut just a half turn on each and try it out. If this doesn't
make it turn better try another half turn. If tightening them doesn't help then
you may need to replace the clutch disk's. This is fairly easy also. just take
off the nuts, remove the chain sprocket on each shaft, replace the disk and
put it back together. I have a service manual that I got with my machine and
most of the repairs are explained and seem fairly easy. Hope I helped.
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
CHAMPION 7500 WATT GAS GENERATOR (A51248)
CHAMPION 7500 WATT...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
