Bobcat 553 Aux Hydraulic Connection Problem
   / Bobcat 553 Aux Hydraulic Connection Problem #1
shakey jake
Fort Calhoun, NE
John Deere 750, Bobcat 553
I have a Bobcat 553. I use the aux hydraulics to operate the grapple on a stump bucket. When putting the stump bucket on, the quick connect fittings won't go together unless I loosen a fitting on the Bobcat's hydraulic line to bleed off some fluid. How can I fix this? Am I doing something wrong? Is the problem with the Bobcat, the bucket, or the inexperienced operator?
Thanks for your time.
Kevin
   / Bobcat 553 Aux Hydraulic Connection Problem #2
You should not have a pressure problem on the BobCat side if you wiggle the levers or cycle the switch if solenoid operated.
Your attachment will develop pressure due to the temp.
You could build a dummy QD and a short length of PVC and stuff a rag inside, and then put a PVC cap and bore a vent hole. Plug this dummy into your attachment QD. Any leakage should be caught by the rag.
If done correctly, there should be no pressure in the attachment.
Good idea JJ. Does it matter which QD fitting on the attachment I use (male or female)?
Thanks...
2007 GMC C4500 Mechanics Truck (A52384)
2007 GMC C4500...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
2021 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2021 SMITH...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2024 BOBCAT T770 SKID STEER (A51246)
2024 BOBCAT T770...
(3) PIVOT TIRES (A51248)
(3) PIVOT TIRES...
