Bobcat 463 won't start / keep running
/ Bobcat 463 won't start / keep running #1
ElaineP8
My son ran the 463 out of gas and now it will only start briefly, even with about 1/2 gal of new gas in it (need to get more tomorrow). Hydraulic fluid is low but not dry. Ran like a top until now. Any ideas?
Thanks,
Elaine
/ Bobcat 463 won't start / keep running #2
Did you actually put gas in it? I googled the Bobcat 463 and everything I saw said it uses a diesel engine. If you did put diesel in did you prime the fuel system?
/ Bobcat 463 won't start / keep running #3
I was going to create a thread to see if others could figure out what my problem was (I've since figured it out).
I'll talk about it here instead in the small chance it might help you.
You surlely have a diesel and not gas?? Presuming so, you might want to check your water seperator.
My situation: I have an industrial backhoe. I've been using it recently however, it was operating a bit weird. It was seeming to me that I didn't have the RPM's that I thought it should.
As I continued to use it, the problem became more clear. From a cold start, I'd have normal RPM's, but as I pulled away my available RPM's would simply die and all I had was idle.
I could have the accelerator FLOORED and it would still do nothing more than idle.
If I turned machine off, waited a moment... (I also found that if I pumped on the transfer pump manually) I would then get full RPM's back for a moment BUT, that would soon go away and I'd be stuck back at idle.
I began to suspect a clogged filter so I took my filter/water seperator off and don't you know, the moment I looseened the bowl, out came the water.
I now realize that I was reaching the limits of water and it was starving the machine for fuel even though I had a full tank.
Dumped water, replaced filter, fired up and runs like a champ now.
Just a thought.
/ Bobcat 463 won't start / keep running #4
The 463 runs on diesel fuel, if you did put gas in it you need to drain the fuel tank and replace the fuel filter then prime the system using the primer bulb and may be you will have to crack the injectors, any other questions you can contact me at parts@parsonstractor.com
1996 International Water Truck with a Caterpillar Engine (A63118)
1996 International...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
