Bobcat 463 pump belt tensioner
   / Bobcat 463 pump belt tensioner #1
brain55
Veteran Member
Brentwood, CA
Is the only way to replace the broken spring on the tensioner to remove the engine and pump assembly. I managed to get the broken spring out, but there doesn't seem to be a way to install the new spring and set the tension with the engine and pump in the machine.
Brian
   / Bobcat 463 pump belt tensioner #2
Did you get it replaced?
My Versahandler service manual says to unbolt the engine mounts and move it forward for clearance. Don't know about skid steers.
No, I'm not going to get to it until tomorrow, had too much other work scheduled. I don't need to pull it all of the way out, but darn close. The engine has to clear the frame and at that point there isn't much left.
Brian
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
MANITOWOC QD08902A ICE MAKER (A51248)
MANITOWOC QD08902A...
2018 TAKEUCHI TB290 EXCAVATOR (A51246)
2018 TAKEUCHI...
JOHN DEERE 54D LOT NUMBER 148 (A53084)
JOHN DEERE 54D LOT...
