Bobcat 463 cooling system question.
   / Bobcat 463 cooling system question. #1
ronreece
san diego, ca
bobcat 463
Just bought a 463 Bobcat and stumbled onto this great forum!
(not sure which forum this question should be posted in)
I have a couple issues I'm dealing with regarding the cooling system on my 463.
Firstly, the temp gauge in the cockpit of the Bobcat is not functioning.
I've grounded out the gauge, and the needle jumps to full hot (which shows the gauge is operating properly).
Next, I grounded the wire out, that goes from the sensor located below the thermostat housing up to the gauge, and it also pegged the gauge at full hot (which shows the wire from the sending unit to the gauge is ok).
I then removed the sending unit from the motor and tested the resistance with an ohmmeter, and the reading came back within range.
So now I am at loss. Why isn't the gauge working when all the parts in the system seem to be functioning correctly?
From what I have been told, the 463 has two different types of sending units that were installed over the years. Both are installed in the same location, at the base of the thermostat housing. One has a single wire that goes directly to the gauge itself. The second type of sending unit (that is in my Bobcat), has two wires - a black wire and a white wire. I assume the white wire goes to the gauge and the other wire goes to the fan (or fan relay).
Second issue, the engine seems to be running hot. I thought it might be a bad thermostat, so I removed it and it still runs hot. The inlet side of the radiator hose - going from the thermostat up to the right side of the radiator is hot, while the left radiator hose - going down from the radiator to the water pump is cold. Also, the right side of the radiator is very hot, while the left side is cold.
I'm wondering if the radiator is maybe plugged up, or possibly the water pump isn't working properly?
Anyone have any advice or ideas? I sure would appreciate any feedback...
Thanks!
   / Bobcat 463 cooling system question. #2
First - Welcome the TBN.
The 463 is a skid-steer loader considered construction equipment so this is correct place to post the question.
From what you are describing - gauge in-op but wires and sensor ohm out, plus heat at incoming side of radiator with cold at outlet to pump - lead me to think the coolant level is low or possible radiator obstruction but first thing to check is coolant level. The gauge will not function when coolant level gets low to point of where there is more air/steam than hot coolant, the sensor cannot read air temps.
Take radiator cap off and check level, top off if necessary then start engine and let it run until thermostat is open and coolant can be seen circulating.
If you find the coolant level is low and the coolant continues to burp out the radiator fill when engine starts then it is most likely blowing it out due to cracked head.
   / Bobcat 463 cooling system question. #3
Try grounding each wire at the sensor. One is for the gauge the other is for the fan. With the key on you should be able to turn on the fan or peg the gauge when grounded. Have you checked the fuse and fan relay?:thumbsup:
2015 Ford F-650 XL Super Duty Ext. Cab Forestry Chipper Truck (A49461)
2015 Ford F-650 XL...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A51039)
2022 JCB 3TS-8T...
