jsvidrine
Bobcat 335 Excavator was running fine when parked. I have owned it for three years and is not used daily but is one of those great Kubota engines that always started immediately even with a weak battery. it sat for about three weeks after using it for 4 consecutive 3 hour days when I went to start it with ignition key and nothing, no clicks no lights on console, nothing. I even tried with the operator interlock (Left side operator console) in the down or closed position, no difference.
Trouble shooting included new battery; cleaned connectors, check all fuses nothing open, visual inspection of wiring harness; found nothing unusual with harness as far as i could see without tearing into machine. Opened the console and check wiring behind the panel; nothing obvious. Jumped hot wire from battery to starter and was able to get the starter to operate.
Checked voltage to the starter switch, found to have weak voltage (3vdc) on red wire after the three wire switch connector (where the switch assembly connects to harness) Decided to "hot wire" by shorting the red and green ignition wires, got lights on the console and an unreadable mixture of images for a code but nothing else. Added hot wire from the battery to the shorted red and green, engine turned over, started and ran as long as the hot from the battery was connected, remove that wire and the engine would die.
Is Ignition switch bad? Would like your advise before replacing bobcat replacement part is like $175
Jv
Jv
