Bobcat 335 excavator panel / controller
   / Bobcat 335 excavator panel / controller #1
Roughryder
I first thought the key switch was bad. Sometimes it would light up the panel and sometimes not. When it did light up everything worked as it should. Now the panel doesn't light up except for perhaps the seat belt indicator. Even this is not consistent. Often just 1, 2, or 3 "idiot" lights will flash when the key is turned. The starter will always turn over but without the fuel solenoid receiving directions from the panel the engine will not start. I have checked grounds to the panel and I believe them to be good. Fuses all tested good. I jumper the key switch and still nothing.
So, any ideas ?
   / Bobcat 335 excavator panel / controller #2
MX needs plugged in at dealer to check service codes. Check "switched power" relay. Possible bad MX display controller.:confused3:
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
