Bobcat 335 ex dripping fuel.
   / Bobcat 335 ex dripping fuel. #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
My Bobcat 335 with only 350 hours is leaking fuel. I filled it up and noticed that it was dripping the next day when my tracks were wet. My first reaction was cracked fuel tank or a hole in the tank. After cleaning it up and looking closely, I found under the front left of the housing where the fuel tank is visible a rubber grommet (drain?) on the tank that was dripping fuel. I tried turning it, pushing it in and it only dripped more. It would be a heck of a coincidence if it was leaking from another location, too, so I'm curious if that's a common problem and if it's a simple grommet to pop out and put a new one in? Is it just a drain?
If the fuel tank had a crack somewhere, how big of a job is it to remove it?
Thanks in advance for any information!
Re: Bobcat 335 ex dripping fuel. update
replaced the front fuel tank grommet/drain. So far, so good. Will check again tomorrow to see if the leak stopped.
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2011 Ford F-150 4X4 Pickup Truck, VIN # 1FTFX1ETXBFC66737 (A51572)
2011 Ford F-150...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A51572)
2000 Isuzu NPR-HD...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
