Bobcat 322 mini excavator hydraulic issue
   / Bobcat 322 mini excavator hydraulic issue #1
Waveslayer
Bobcat 322
My old neighbor has a Bobcat 322 and the hydraulics quit after 15 minutes of run time then its back to normal in a hour or so for another 15 mins until the hydraulics quit . The blade functions still but the joystick hydraulics slow down and then stop completely within a few seconds including travel as well. There is power at 2 of the 3 solenoids at the manifold with the yellow zap strap 2 speed not working though he tells me that hadn't worked in years. There is still pressure at all 3 pump chambers but when I put the test gauge on the manifold test ports neither has pressure when the failure happens but obviously have pressure when the hydraulics are working for that 15minutes. The pressures when maximizing cylinder travel hit 2300psi. I am a little stumped as to what to check next.
Cheers
Steve
   / Bobcat 322 mini excavator hydraulic issue #2
I have a Bobcat 322 also and have a similar issue that I can't diagnose.
In my case, only the left track stops pulling when the machine gets good and warmed up. It may be my track motor, but I don't want to change the $2000 motor if that's not the issue, and I don't know how to tell for sure the motor is bad.
My 2 speed also does not work properly, but I think it may be a bad electrical connection somewhere. It will jump in and out of high speed as I am traveling along.
Massey Ferguson 130 (A50121)
Massey Ferguson...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2011 New Holland B95B Backhoe (RIDE AND DRIVE) (A50774)
2011 New Holland...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
