Bobcat 3023 tractor hydrostatic drive problem
   / Bobcat 3023 tractor hydrostatic drive problem #1
stevet79
Bobcat 3023
I have a Bobcat 3023 tractor with trencher and when it starts pulling hard the drive system disengages and goes into freewheel mode. If you are on a hill it rolls. The only way I can get it to re-engage is to shutdown the motor and restart it. All other hydraulic functions continue to work when this happens.
Any help would be appreciated.
   / Bobcat 3023 tractor hydrostatic drive problem #2
what is this machine . Do you can take a picture ?
   / Bobcat 3023 tractor hydrostatic drive problem #3
Sounds like your describing a relief valve failing. Dose it fail in both directions? :confused:
I had given up on this thread.
Yes it fails in both directions.
Thanks for your reply.
S
   / Bobcat 3023 tractor hydrostatic drive problem #5
Can you post the sn# ? :thumbsup:
This issue still exists:
I'm offering a reward to the person or persons that can tell the fix for this is. All I'm asking for is the knowledge you might have and if what I'm given fixes the problem I'll pay $$$.
Any takers?
ST
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
1985 International X Con Semi (A50514)
1985 International...
