bluetooth deadman ignition switch
   / bluetooth deadman ignition switch #1
relaqbr
north east San Diego Co.
Toro TX420
Okay why is this harder than it looks. I want it to be optional. So that I can turn on the system only when I'm doing specific things on the tractor. I definitely do not want it tied to the seat in anyway. I have googled and googled and googled and can not find anything that seems reasonable. I was thinking I could do it with a long wire but bluetooth would be so much better and not have a wire trailing me around. Has anyone done something, seen something, built something?
Bob
   / bluetooth deadman ignition switch #2
I don't understand. What would this be used for? In case the tractor threw you off and kept going?
Sent from my SCH-I500 using TractorByNet
   / bluetooth deadman ignition switch #3
Not a Bluetooth solution, but how about a simple on/off switch next to the seat? Just tie it to the existing wiring.
David Sent from my iPad using TractorByNet
   / bluetooth deadman ignition switch #4
blue tooth? so you can fall off and the tractor continue going ? 25-50' befor ethe signal is lost?
or when you drive under a power line and the signal drops and you stall? :)
RFID might be a lil more forgiving as an op presence switch.. and a magnetic switch with a tethered dongle even better..
   / bluetooth deadman ignition switch #5
Do you want a deadman switch (hold down to keep the tractor on), or just remote shutoff switch? If just a remote shutoff switch, take a look at something like: 4 Channel RF Wireless Remote Control 433MHz Latch New | eBay I have 2 of them in our cars to lock/unlock both cars with 1 remote. It could also act as a deadman, but it would be a pain to use.
Aaron Z
Thank you for all the replies. But no, really, like I said, I don't want it tied to this seat. And no I have not fallen out of the seat lately knock on wood. I guess none of us are ever off the seat working on external equipment. To be specific I have a concrete mixer off the front quick attach. It is rotating and there are places to get hung up on. I thought it would be smart from a safety perspective to have a dead man's switch when I'm off the seat working with the concrete mixer. I also have put a small hydraulic motor on a shredder and run it at various times with the tractor hydraulics. Both of these pieces of equipment would be better safety wise with a deadman switch to the tractor. And if the switch is too hard to activate -- It would be it would be too hard to activate as I am being mangled.
Thanks for all the replies!
   / bluetooth deadman ignition switch #7
So you want something that you have to keep pressed in order for the tractor to continue running? That's going to be tricky. With wireless, a quick loss of signal, and the tractor cuts off in the middle of you doing something. With wired, it'd be a *lot* easier to do, but you're on a leash and can't easily walk around.
If this almost always involves standing by the 3PH, I'd suggest looking at... find a wire that keeps the tractor running. either the ignition switch or a safety. Find a jack that remains closed when nothing is plugged into it. Mount the jack on the rear of the tractor and splice it into the wire you found earlier, so that it is in series with whatever else is there (ignition switch, safety, etc). Make you a harness with a connector that fits into that jack and has a momentary, normally open, switch on the end of a 5/10/etc foot wire harness with a nice comfortable handle. You release the switch, the circuit opens, the tractor dies. Need to go grab that branch out of your reach, unplug the jack and everything works like normal until you get back and plug it back in. I think something similar to this may be available for boating, but it would be for you being a certain distance away (i.e., overboard).
This is somewhere that you probably want to stick with the KISS principle. Bluetooth is just a way to communicate. You'd need to build smarts on each end so that something exists to communicate over the bluetooth.
You may also consider adding a siren so that it will let someone know you're in trouble.
Keith
   / bluetooth deadman ignition switch #8
On the shredder, I would do like the commercial chippers have, a U shaped arch around the hopper that controls the hydraulics for the feed rolls. If you push on it as you get dragged in, it reverses the feed rollers and things back out.
On the mixer, I would have a loop of rope that comes out on standoffs like a "fence" around the mixer (to there you can reach it) and pulls on the lever of a hydraulic valve (like a woodsplitter valve) to shut off the mixer.
Aaron Z
Thanks again for the replies. I did notice the boating reference and have googled all sorts of boating switches but still can't find anything like what I am looking 4. okay I said bluetooth but I really do mean just wireless. Bluetooth is a very effective computer chip to computer chip wireless transmission system. And everything these days is computer chip.
I am thinking of adding additional hydraulic systems and I do not want a separate shut off system for each one. -- KISS!!!
   / bluetooth deadman ignition switch #10
have not looked in years but possible some type of RC model control and a servo to operate what ever you want, when my son was at home we bought a lot of stuff throught a company called tower hobbies, Tower Hobbies - Best Source for Radio Control ( R/C or RC ) Cars, Trucks, Airplanes, Boats and Helicopters
they have some 2 channel radios, TowerHobbies.com | Shop by Category: 2-Channel Radios - AM Pistol that way one could run two items via a reciever and servos,
the have transmiters with many more channels as well,
some info on the systems, EasyRC.com
CFG Industrial SAII100 (A50123)
CFG Industrial...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
