Blueford is not cool anymore....
   / Blueford is not cool anymore.... #1
mojoinco
Platinum Member
Colorado
TN55
Hola Friends!
I figure there isn't much to add to this, but seeing as how this is a free post....
I found out Saturday that my AC is not working (it finally got warm enough to tell -- I have only had Blueford for ~ 2 months). Anyhow, 1998 Ford-New Holland Tn55 (yep, still says Ford on mine). R134a freon, compressor clutch appears to engage (everything is turning). Figuring on a service drop off to get it fixed. Unless someone has a magic elixir that will do otherwise -- or point that I may have missed? Low hours (~580). An independent repair shop down the road a few miles (might just have the little woman meet me instead of loading him up).
   / Blueford is not cool anymore.... #2
I would think any auto AC service shop should be able to service your air conditioning. It sounds like a charge of R134a is probably what you need. They may be able to add dye and see where it is leaking. I hope the compressor seal is not gone. That could be expensive.
   / Blueford is not cool anymore.... #3
hopefully you have kept the condensor clean.
   / Blueford is not cool anymore.... #4
I'd agree with the others.. if you have an auto /ac shop in roading distance.. I'd start there.
does the compresor kick on/off fast.. if so.. low pressure.. etc..
good luck.
soundguy
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
