Blue screen pc
   / Blue screen pc #1
Rustyiron
Super Member
Lakes Region, Maine
M 9540 Kubota
Is it hopeless? Any of you guy's know if any thing, mostly pics & music is retrievable from a pc with the blue screen of death? I have most of it on an external "hard drive" thingy, but not all of it. I'm switchin' teams, to a Mac. Any tips?
   / Blue screen pc #2
ive always been able to recover everything from a dead drive....AS long as the drive is still able to turn. Any computer geek (geek squad, whatever) can plop the old drive along side a new computer and drive and just access it like an additional drive
   / Blue screen pc #4
If you are getting far enough to blue screen you have a good chance of easy data recovery without too much expense. I would recommend you stop messing with it and get your data off though. If the drive is dying every spin up could be its last.
   / Blue screen pc #5
as has been said. if the drive operates.. plenty of ways to mount it..
   / Blue screen pc #6
even those "dead "drives can usually be "revived" temporarily by placing the computer on its side or upside down and firing it up again... ( loads the hard drive bearings in a different plane )
invest in an external USB hard drive adaptor and borrow another computer with a DVD burner ... hook up the almost dead HD to the adaptor and plug into the borrowed computer's USB port , copy the data to a DVD / USB stick, etc
   / Blue screen pc #7
I have always backed up my computer and data to a external drive. I have experience several "Blue" or "Blank" screens over the years. One of the best backup programs I have ever used was the DOS program "Fast Back". Windows 7 Ultimate and Professional both have what I consider an excellent backup program. I have used "Back Up Restore" in both Ultimate and professional to repair or replace a damaged hard drive.
Have you tried booting from the DVD and doing a repair? That might solve your problem if the blue screen is being caused because someone had a thought, what happens if I push this.
Can you boot into "Safe Mode" and do a repair?
Are you getting just a blue screen, or are you getting a blue screen with numbers and other data displayed along with a error code string of numbers?
   / Blue screen pc
I'll take some where. You guy's makes it sound like there is hope, but most of you're words are jibberish to me:confused3: thanks! This and a few other forums are about the extent of my computer needs or use.
   / Blue screen pc #9
if switching to Mac ... just bring the beast in and have them transfer the files over to the Mac for you .... a lot of mac stores will do it free of charge.
   / Blue screen pc #10
I've recovered files for people (never charged, just as a favor) by hooking the drive to another PC using an adaptor and just copying the folders over. If someone has a PC with an extra slot, it is dead easy to hook the drive up (assuming the correct type connectors are present) and see if the drive spins up and is assigned a drive letter (sometimes you need to change the settings on the drive to slave). In one case a drive containing crucial files would not spin up, so I purchased another of the exact same drive off eBay for $5, switched the circuit board onto the dead drive and it woke right up. I still have an inexpensive stethoscope I used for listening to the drive for signs of life.
I still use PCs but considering a MacBook Pro to replace the current Lenovo laptop.
UNUSED FUTURE 13' 200 AMP JUMPER CABLES (A58376)
UNUSED FUTURE 13'...
Sedan (A59231)
Sedan (A59231)
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2021 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
1 BOTTOM TURN PLOW (A58375)
1 BOTTOM TURN PLOW...
2013 Felling Trailers 8 Ton T/A Side Dump Flatbed Trailer (A56858)
2013 Felling...
