blowing safety system fuse #2 on TC40D
   / blowing safety system fuse #2 on TC40D #1
jacksotheby
I have just had a similar issue with the fuse #2 on the TC40D as have been reported in earlier posts. There are no obvious wire problems with only 160 hours. From one moment to the next the fuse constantly blows when the ignition is turned to the starter engage position. Is there any safety system bypass on this tractor? Can someone tell me where the neutral position switch is located and which relays in the array are those for the safety system? Are there other components to check? How have similar problems been resolved? I will try replacing with the 8 Amp circuit breaker but given how strongly the fuse blows I doubt this will correct the problem - it seems to be a direct short.
   / blowing safety system fuse #2 on TC40D #2
I have sent jacksotheby a PM, offering to send him the schematics as an email attachment. I don't want to post them here because they are copyrighted, and that puts TBN at risk.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2012 Honda Civic Coupe (A50324)
2012 Honda Civic...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
