Blow in Ceiling Insualtion as Ceiling is Installed
   / Blow in Ceiling Insualtion as Ceiling is Installed #1
monteu
Bronze Member
NE Kansas
Kioti DK5010
Blow in Ceiling Insualtion--Celluliose or Fiberglass??
Going to put the sheet metal ceiling up in pole barn tomorrow. I have this idea of blowing in the ceiling insulation as we go rather than crawl around up there later. I have called and got prices at two lumber yards. One reccomends celluloise blow-in and the other reccomends fiberglass blow-in. Which one is the preferred insulation? I am confused.
   / Blow in Ceiling Insualtion as Ceiling is Installed #2
Blown cellulose or fiber-glass? I've only had one experience with cellulose, but I think you are going to put a lot of paper dust in the air doing it that way. It's not good to breathe, you should wear a good respirator/mask when blowing.
I think sheet metal ceilings are nice looking and should be maintenance free. Decent fire resistance too. When putting insulation above sheet metal, do you use a vapor barrier or seal the joints in some way?
   / Blow in Ceiling Insualtion as Ceiling is Installed #3
Going to put the sheet metal ceiling up in pole barn tomorrow. I have this idea of blowing in the ceiling insulation as we go rather than crawl around up there later. We are running the sheet metal parallel with the trusses. I would put up approx three widths of 36" sheet metal and then blow the insulation on top. Then continue on and so forth. The truss would sort of act as a barrier to keep the loos insulation from falling. Make sense and what do you think?
I would blow it all up after installing the ceiling. Like Dave1949 said you will be working in dust. It is so easy to blow insulation with a helper. My son and I insulated my 40' x 60' shop in a few hours. I let him crawl around the attic while I fed the bales into the blower. Kept the blower outside the shop and there was only little cleanup required afterwards.
   / Blow in Ceiling Insualtion as Ceiling is Installed #4
Re: Blow in Ceiling Insualtion--Celluliose or Fiberglass??
While I'm sure that neither is good to breathe, I see cellulose as the less irritating of the two .... just something about breathing shards of glass I guess.
In terms of insulating, apparently cellulose provides somewhat better performance.
   / Blow in Ceiling Insualtion as Ceiling is Installed #5
If by "decent" you mean a little better than nothing, then yes.
   / Blow in Ceiling Insualtion as Ceiling is Installed #6
How about "not combustible" :laughing: Thinking of sparks or whatever that wouldn't be able to start a fire. If it's 29 ga., I'm sure a hot fire gets through it pretty quickly.
   / Blow in Ceiling Insualtion as Ceiling is Installed #7
I'll stay with 5/8 drywall.
At least then, I won't wonder if it would have mattered in a fire. :thumbsup:
I have slid pre-cut 4' fiberglass insulation batts on top of the drywall, as it was being put up. That sure made the job easier.
   / Blow in Ceiling Insualtion as Ceiling is Installed #8
When they insulated my house they gave the option of stapling up a polyester "fabric" before putting in the ceiling and then blowing the insulation up through that to avoid having to crawl around in the attic to do it after the ceiling was in.
   / Blow in Ceiling Insualtion as Ceiling is Installed #9
I think that blowing in the insulation came about because of the "crawling issue" in ceiling and some of the really tight spots sometimes go no insulation because you physically couldn t get into the small areas to put in bats. A good dust particle mask is a necessity for either. I prefer the glass insulation over the cellulose simply due to fire hazard. I know they claim the cellulose is treated for fire retarding but, I know glass doesnt burn and paper sure as heck does and small critters seem to like the paper better than the fiberglas. I also think the cellulose settles more and quicker than the glass. The trapped air is the insulator and if the fiber settles it has less insulation value.
Back to the question of when to install it. I suppose that if you were carefull, you could blow it in as you installed a few panels, but why bother. If you are up in the rafters, its going to be hot either way you go and getting the stuff level a bit at a time might be problematic not to mention time consuming on rental of the machine to blow it in. The dealer might not want his machine out for the period of time necessary for you to blow a bit and put up tin, then blow some more. Typically a blown in job is less than an hour to install a whole house system.
   / Blow in Ceiling Insualtion as Ceiling is Installed #10
Don't discount the fire barrier value of a metal ceiling. Many people mistakenly assume that fire rating is based on insulation capability. It's actually based on the resistance to burning, burning through, and transmitting heat. As a roof, 29 ga. metal is Class A rated. You would need a major fire to ignate insulation above a metal surface because it spreads the heat as it conducts it in all directions. Some people prefer the fiberglas, but the most common approach is cellulose for both price and performance.
In any case, make sure you have the vapor barrier in place above the steel.
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
